Before you can add Identity Verification to your envelopes, you must have the feature enabled in your DocuSign developer account. If it’s not already activated, please reach out to the DocuSign support team through DocuSign Support and request activation. You’ll also need to request activation for your production account before you can use Identity Verification there.
Obtain identity workflows available on your account (using the IdentityVerification:list API) and extract the workflowId
associated with the one that you’d like to use.
Request:
Headers:
Authorization: Bearer {code}
Response:
"identityVerification": [
"workflowId": "{workflowID}",
"workflowLabel": null,
"defaultName": "DocuSign ID Verification",
"steps": [
"name": "identify",
"type": "EnvelopeAccess"
"signatureProvider": null,
"inputOptions": []
"workflowResourceKey": "",
"steps": [
"inputOptions": [
"isRequired": true,
Request:
Headers:
JSON Payload:
"compositeTemplates": [
"serverTemplates": [
"sequence": "1",
"templateId": "{templateId}"
"inlineTemplates": [
"recipients": {
"signers": [
"email": "{recipientEmail}",
"name": "{recipientName}",
"recipientId": "1",
"identityVerification": {
"workflowId": "{workflowId}",
"steps": null,
"inputOptions": [
"name": "phone_number_list",
"phoneNumberList": [
"sequence": "2"
"status": "sent"
Response:
"status": "sent"
- Using Identity Verification with templates
- How to require phone authentication for a recipient
- How to request a signature using a composite template
- Why You Should Be Using the Composite Template Model
- DocuSign Developer Center
- @DocuSignAPI on X
- DocuSign for Developers on LinkedIn
- DocuSign for Developers on YouTube
- DocuSign Developer Newsletter
