Already, fans of Microsoft Power Automate (previously called Flow) will know that it’s a great tool for streamlining repetitive tasks and making processes paperless. It’s why the tool is such a great fit with Docusign – we’re all about going paperless and automating key tasks, too.
Our example: Creating a workflow when a new file is created in SharePoint
- In procurement, a trigger could occur when a tender/project status is changed in a SharePoint list to automatically send an approved contract for execution
- In HR onboarding, when a new employee is added, the onboarding pack (personal profile, payroll data collection, NDA, etc) is automatically sent through an approval and signature workflow
Step 1: Docusign Setup
- Login to Docusign Admin and make a note of your Account ID (see top left)
- Create an Integration Key, a special key that enables the API-level authentication:
- Go to Integrations > API and Keys, and note down the “Account’s Base URI”. We will refer to this as the Base URL.
- then “Add App / Integration Key”, note down the Integration Key
- Select “Authorization Code Grant” radio button, then click “Add Secret Key”, and note down the Secret Key
- Click “Add URI”, and add the following: https://global.consent.azure-apim.net/redirect (this may change as its generated by Power automate, but this initial value will work for now). Please note down this value of the Redirect URI for now.
- Create Custom Fields
- Go to Signing and Sending > Document Custom Fields, click “Add Field”
- Choose which fields you’d like to add (e.g. signature, name, signing date) and follow the prompts. For example, if you want to add a Signature field, the recommended values are:
- Name: Signature
- Type: Sign Here
- Shared: Tick (yes)
- AutoPlace Text: \s{r}\
Create a Custom Connector
General
Input these details below:
- Host: Base URL [captured earlier]
- Base URL: /restapi/v2.1
Security
DEMO:
- IKey: Integration Key [captured earlier]
- Secret Key: Secret Key [captured earlier]
- Authorization URL (DEMO): https://account-d.docusign.com/oauth/auth
- Token URL (DEMO): https://account-d.docusign.com/oauth/token
- Refresh URL (DEMO): https://account-d.docusign.com/oauth/token
- Scope: signature extended
PROD:
- Authorization URL (PROD): https://account.docusign.com/oauth/auth
- Token URL (PROD): https://account.docusign.com/oauth/token
- Refresh URL (PROD): https://account.docusign.com/oauth/token
Definition
Enter these values:
Verb: POST
URL: https://demo.docusign.net/restapi/v2.1/accounts/[your Account ID]/envelopes
Body:
"documents": [
"documentId": "1",
"fileExtension": "txt",
"name": "Doc1",
"order": "1"
"recipients": {
"signers": [
"recipientId": "1",
"roleName": "Signer 1",
"routingOrder": "1"
"status": "sent"
Test
Inputs:
- Site Address: - Sharepoint site
- Folder id: Folder path
Get file content
Inputs:
- Site Address: Sharepoint site
- File identifier: – This is the output from the previous step. Simply select “File identifier” under “dynamics content” on the right pane. See above screenshot.
Compose
Input
- Inputs: “base64(…)” – within the brackets, go to “dynamic content” and select the “Get file content” (As below). The final function should read:
base64(body('Get_file_content'))
Add Custom connector
Select the Action we created.
Now add the following values:
- documentId: 1
- fileExtension: txt
- name: Doc1
- order: 1
- emailSubject: Send document for signature
- email: [enter signer email address]
- name: [enter signer name]
- recipientId: 1
- roleName: Signer 1
- routingOrder: 1
- status: sent
Note - For these fields:
"email": "[enter signer email address]", "name": "[enter signer name]",
Now save and run it!
